Hi All,
Can anyone help with some info on where the sofware chip in the monitor part of the AV9000 television is?
I have just bought a replacment AV9000 for my old one which had become faulty.
The old one was a type 43/03 software 1.2 and dated from 1994 and was a 2 way working set with a Beolink 5000, a beo4 would also work this set as well for some reason.
The replacement set is a type 79/03 software 2.0 dating from 1995, this has Beo4 on the sticker on the back of the set and is a one way working remote set only as it stands.
Looking at the info of the web, this beo4 AV9000 is one of the very first one way versions, it still has the bottom amp part with software 1.1 as the old Av9000 i had.
I'm hoping swapping the circuit board with the software chip from the early Type 43/03 and fitting it in the later Beo4 version will make the later set 2 way operational.
Has anyone done this with success?
Do i need to swap anything else between the 2 sets? i believe there is some difference in a teletext board, but as i dont use teletext i carnt see that being an issue.
thanks,
Phil
