Is there anything that can be done to fix this?
Once the Anti Reflective coating has been scratched, there's sadly nothing you can do to repair it properly.
Whatever you do, don't keep rubbing it as you'll make it much worse. Unfortunately, the screen on a BV10 includes the aluminium surround - so they're quite pricey!
Lee
I have to change it then, it is very annoying to see. How much is quite pricey?
I´ve been quoted approx 8000 SEK including labour. That is approx 930 eur. I will swap my screen, since I do not have antireflection.
Just ordered a new screen, including help with mounting and picture adjustments. 7500 SEK.
Will be nice to get rid of the majority of the reflections.
/C
Screen changed yesterday.
Very swiftly done by a service guy. 3- 4 screws, and just lift of the old screen. Put on the new, and make some adjustments in the picture settings. Guide for the adjustments was provided by B&O.
Very satisfied, and actually less expensive than choosing the AR screen from the beginning.
/C
/C
That's interesting! 🤒
I have the AR screen, as I've always thought this is what makes the Beovisions great.
Enjoy your new screen.
It's a standard fit in the UK. I have never understood why a picture competence is an option???
What do you mean by "picture competence"?
