sLIGHTLY OFF TOPIC BUT SEEKING ADVICE
I usde a bv7-32 with an stb shelf slung under the 7.1, on this shelkf is a rather large panasonic sky box, somewhere in the past i remember seeing a small slim freesat box which, i should have bought at the time, however i now seek any input as to a small footprint not tall freesat hd box - anyone
salut
tony
Bump  - anyone, ideas / sugestions?
t
Hello Tony, I have three freesat boxes, although not used with B&O.
They are made by HUMAX and are very small and slim... Try your favourite auction site
Cheers Russ
Thanks for that!
Eventually found a Comag SL40hd - noew its here, I think the original box I saw was by Elap, probably the same unit with a different badge on it  -  the box is
22cm wide x 17cm deep(ie front - back) x 4.5cm high - now just need to fabricate a shelf for the stb tube shelf on my bv7-32 then I can place the small footprint TNT box on the shelf and the Comagmounted underneath as a semi permanent fixture - photos later!
Now to find the IR eye to control it9if possible with the Beo4!
salut
Tony
Your CAPS LOCK key is on!!
WeLl SpOtTed
