I've got a Hisense 75' 4k via HDMI from my Sky Q and i want to put sound only into my BS3.
This has caused some problems, because the coaxial/optical converter give no sound to the BS3 on any setting i change on the Sky Q. So plug into the optical out of TV, same result. Use an Optical/ Stereo converter into BS3 i get sound, but not DD.
Plug my DVD 1 init the optical, i get sound, so in know the input works, i know the optical output works.
Ive changed the optical converter 3 times, different makes.
Ive used an HDMI splitter, that gives me DD into the BS3, but then i loose the 4k. Also tried my PS4 optical output swell as Apple TV, same result.
In my ideal world id love output from the TV optical and have all my devices connected to the tv, so i can just switch inputs and the sound follows,,,,,,in DD not stereo,,,,,
