My apologises if this topic has already been covered, but I would appreciate any advice on the benefits (or otherwise) of switching to a large capacity (1TB) Sky HD box. At present I am on my seventh Sky HD box which attached to a BV7-40 Mk II. There are perpetual problems with the "handshake" between the box and the 7-40. For example, there frequently is the message"this diplay doen not support HDMI". Sometimes there is sound but no vision, just a blue screen. The local B&O dealer has been very helpful and re-fixed all the connection, but these problems still occur. The SCART is connected and is on.
So are the electronics on the large capacity Sky box more robust and less sensitive to minor connection variations than the standard HD box? The 1TB box is priced at about £250, but if using it leads to more consistent connections when my wife switches on the tv, it will be money well spent.
Villarsch
