tournedos wrote:
Radio is techy stuff 😁
I try to behave like a human being and refrain from singing. Whistling, on the other hand...
Evening everybody!
I honestly believe that you should have to pass a test before you are allowed to whistle in public!!😠 Many people will happily acknowledge that they can't sing and couldn't carry a tune in a handbag but no one thinks they can't whistle!! In fact whistling out of tune is probably the most annoying thing you can do in public and offenders should be shot on the spot!
I've nothing against whistling per se, and if you can actually follow the melody and manage all the necessary trills etc. it's perfectly harmless, ...........if not, it set's others teeth on edge worse than rubbing glass with polystyrene.
Of course, if you're whistling out of tune on purpose, specifically to annoy folk, in perhaps a work situation, then that could be called sport!😜
