Should I change my Beovision 7-55 mark2 to an Eclipse 55?
I am considering changing my 5,5 year old Beovision 7-55 mark II to an Eclipse 55. Do yoy guys think it is a good thing to do or what do you think?
I know that the PQ is extremly good on the 7_55. What do you think?
best Regards
I also own a 7 55 mk2 and I have tested the eclipse and the loewe bild 7 in the same store, frankly for everything full hd I still prefer the pq of the 7 55. Its deep black still amazes me even compare to an oled.
If you need 4k then that's another story.
Until 4k is needed and we are far from that due to the lack and interest of the source, at least in France, I consider an "upgrade" a complete waste of money.
Oliv
Hi
great thanks for hour answer.
best regards
The 7-55 is to good tv to change if not need for bigger or 4k. Even the center whit bolab 10 is better. Because the voices is much neerer the center of picture than whit the eclipse. I’m suprised no one ever notised that. You can set the sound higt whit eclipse but it still not good enough.
That was my no go. And the lack of 4k material from viasat parabol.
Thanks for your opinion regarding the beolab 10. I tried every other center speaker of b&o and the beolab 10 was finally the best choice.
There is a perticular thing in the 7 55 that finally brings something more special.
The frame of the new screens from whatever the manufacturer is very thin. The pictures is then close to the wall and its color. The wide frame of the bv 7 gives a cinema style picture. It magnifies the picture when the very deep blacks blend perfectly with the black of the frame.
What I can read from you guys is that it is "stupid" to change a BV 7-55 MKII to an eclipse.
A question: Is the Beolab 7-4 on par with Beolab 10 regarding soundquality?
Best Regards
I have tested every bl7 and for me it is the worth...
Hi Olvisab, Do You know how many "screen"-hours you have in your BV 7-55?
I have 5.500 hours and are thinking of how long time I can keep my 7-55 before it gives up.
Have You heard anything about how well the 7-55 markII hold up against faults of everykind?
Best Regards
I have 5600 hours. The tech guy I know (official bang olufsen service center) has never had any for repair. The life is at least 7/8 times the count of hours we have.
There 2 fans under the tv on each side, check that they work and use an hoover sometimes for removing the dust on them.
