Setup problems BV10/BC2..
I have made the following setups in my BV10.
Hdmi A (PC as source on the remote)
MacMini, Puc1 this works perfect.
Hdmi B (DVD as source on remote)
PS3, Puc2, this also works great.
Masterlink is connected between my BC2 and BV10 and BL3500
All speakers are connected to the BV10.
This works great, I can choose speaker 1-5
Play sources as Radio, CD, A-PC, PC, PS3 and TV all works.
Now to my problem. I also want to have the option to use the DVD in the BC2. I have a scart cable but I cant get it to work. I have tried to set it as DVD2 - I get the options on the tv source Beocenter2, I coose this. No picture and no sound when I put a dvd in the machine.
I have aslo tried to set the BC2 as DVD1 still the same problem..
Anyone who has a solution to my big little problem.. :)
Could the TV be expecting the digital inputs for sound?
Interresting point, I have the setup as a scart in the setup menu. And there are not picture and no nound, just all black when I have a DVD in the BC2. Playing cds and Radio works great so the sound output from both digital and analog works from BC2 to the BV10..
I made complete change in my setup.
The BC2 - DVD had to be the first input (av1) then the options in the setupmenu worked great.
The PS3 - became DTV seemd to work great when I startded the PS3
The MacMini - bacame v.mem works great sawell :)
