Setup in new house
Hi all.
We have almost finished our new house (dec 2007) and I hope someone on here can give a little help if this setup will work or not... or might have any good ideas to do it better, please see drawings at this link (please be patient about me, I'm new into hompages and making links!): link
Livingroom: BV 7-40 MKIII (If it comes here in Denmark) as Master, BS 9000, 2 x BL 5 and 2 x BL 8000
Bedroom: BC 6-26
Kitchen: Link-eye and 2 x BL 4000
Technic: All the other stuff like a STB from the cable-company (TDC in Denmark both analog and digital signals), Harddiskrecorder and might an old VHS
Office: PC including a tuner for analog and STB-T. On this I will put it's own antenna.
And now for some questions:
Will it be possible to see the PC-recordings on the 7-40 and 6-26... if yes, in a good quality?
Will it be possible to see the digital channels from the STB-C on both the BV 7-40 and BC 6-26.
Is it possible to control ex. Sony-harddiskrecorder, STB-C and VHS-video from both the BV 7-40 and BC 6-26 via the PUC-system.
How does PUC work?
Hope You're not irritatet about my questions, I just want the best from the start!
All the best to you all!
;-) Jes
Link quality is pretty good in my experience, I use it. PC recordings are generally not suitable for large screens without some prior setup and I'm not sure how you would get the signal routed though the BV7.
If the signal is from the BV7  then generally yes. If you want to watch HiDef in the link room then the link TV's tuner needs to capable. E.G. The BV8 will not do this.
Perhaps post the model number or the hard disk recorder so that one of our beoworld American friends can look it up. The Mark III BV7 is only releassed there. B&O have their own standard definition analog hard disk recorder, I hope they will support others though I'm not sure.
How does PUC work?
By translating B&O remote functions via a controller and IR lead to IR codes the device understands. The translation software is completed by B&O in Denmark. The PUC also controls other functions such as on/off, timed recordings and the mapping of the device to a Beo4 key. Lintronic in Denmark may also be a solution for you.
Hope that helps..
;-) Jes
Hi Jes,
I'm but i can't help you with your technical questions, but before you start installing I think you take a look at this site:
