I'm finally going to get a settop box to recieve SD signals for my BV6-22. But i'm wondering if I should get a software upgrade for my TV or use my lintronic to operate the set-top box. I plan to get one of those with a digitial harddrive and perhaps a DVD too so i only have one box rather than a stack.
Are the ST boxes and all functions of the HDR fully operational with Beo4 if i buy a box which is listed in the software list? I know i can do anything with prgoramming of the lintronic, although getting the DVR there's no doubt many many settings etc to make.
Anyone had experience with this or have opinions on what's best. I only ask as the software upgrade will cost $$ so if it doesn't really work well then i guess i wouldn't bother and just rely on the lintronic.
Any opinions on easy to use quality SD DVR's would also be appreciated (i'm in Australia)
thanks!
