Settop Box - Avant - DVB T (Strong 5126) - New Chip?
1.
I would like my 2 year old Avant Set top Box to step through the program numbers at my DVBT.
But the Strong 5126 is not on the set top box list.
Can the setting of another unit (on the set top box list) be used to step through the program numbers? It would be OK to handle other issues with the Strong’s remote
Or do I need a new chip, and does the new chip include Strong 5126
 2.
My DVBT states that The Danish TV2 uses AC3, but even though I have SP/DIF connection I don’t get Digital sound. Any advice?
The most recent list mentions the Strong 5200,5300 and 5400. I imagine that they must share some codes with yours. Are they listed on your set? Don't know about the Digital sound but check the box settings as this is usually the problem.
Same Code
Yes, the set top box controller menu has one of them (I think it is the 5300), but it does not respond to this profile.
Box settings
I have set the Strong to SP/DIF output, and connected the box to Dekoder (BC2 uses AV scart), and connected the Strong to Input 2 (SP/DIF).
