I decided to purchase a Beoplay A6 and replace my Bose Soundtouch.
Love the look and the sound.
I also discovered ( with the help of B&O service pros) that the initial setup with iPhone can be accomplished better by using a wired rather than a wireless approach.
1) turn machine on
2) connect the router to A6 by cable - you will hear a little beep and both lights turn white.
3) Turn on your &B&Osetup app
4) find your A6 - look for updates and update - takes 15 minutes or so, flashing red light turns to solid white.
5) go to your A 6 product in the app and select the wireless network you want to join.
6) disconnect the cable and enjoy the music!
No wonder I still prefer land lines to mobile!
