service manual Beosound 8 / beoplay a8 wanted.
Normal 0 false false false EN-US X-NONE X-NONE
Hi there,
I just recently bought a defective Beosound 8. No power up on Ipod/ipad connection, It comes alive and reacts to the remote when using AUX input but no sound emerges.
I measured the voltages on the connector from the power supply to the main board and the voltages between any of the contacts seem very low to me (4.7 Volt Max.). The same voltages happen when the main board is disconnected.
As I do not know the correct voltages nor the specs of the components I am in need of a reference/service manual for the Beosound 8/beoplay a8. Does anyone have this available? On Internet I can only find the user manual.
Coen
Cora2 wrote:
Normal 0 false false false EN-US X-NONE X-NONE Hi there,
Coen
There is a BeoSound 8 Service Manual at BeoWorld main site's Products section.
The Service Manuals are available for download for members with Silver or Gold membership.
Log in, and head to:
https://www.beoworld.org/manuals_view.asp?pid=1284
I hope this helps 🙂
Here's the Index for a quick look at contents:
