Serene mobile phone: fantastic performance but no speaker! Great buy secondhand
I have just purchased a B&O Serene phone used/secondhand but still under guarantee. I wouldn't have paid the full retail price, but could afford it at 60% off retail!
It's a fantastic phone and I would recommend most people to ignore the early (prelaunch?) negative reviews.
Ignoring the full price issue, consider that you get a SIM free phone and are not tied to an expensive package. The phone has a real quality feel to it and the sound quality is extremely good. I found that the upside down screen is actually an advantage as you naturally cradle the phone in your palm using your thumb  on the dial/ wheel whilst getting a clear view of the screen. You can turn the phone over for desk use with the screen at the top and reverse the screen. When you plug the phone into the base docking station the screen is at the top and the display turns over automatically.
The camera is a discrete device in the hinge area. You appear not to be looking at the subject when you use the camera: actually a great advantage with many subjects where you want to get informal shots. The pictures are more than adequate for phone or computer viewing. (Want better quality: buy a camera!) Incidentally, the phone does display pictures in full colour: the black blue and white colours are the pre-sets for the menus.
I would say that the only real disadvantage that the phone has is the lack of a speaker for complete hands-free use. What is the point of having a terrific docking station with automatic opening of the phone when a call is received (when in the dock) only to have to take the phone from the dock to listen to the call! It seems that the use in the dock is really confined to web browsing or text messaging. True to B&O tradition (I have audio equipment from 40 years back) the phone will link to other B&O equipment/ phones for contacts exchange etc but wont readily link to any other manufacturers equipment (although there is  Bluetooth in this case).
Once you get used to the wheel (and avoid touching it when dialing (as brushing it accidentally will jump the curser and jumble up your typed number!)) it makes for very fast access to you phonebook and the phone menus.
The case for the phone by Louis Vuitton looks like a useless (and almost as expensive as the phone) handbag. There is an alternative by Piel Frama of Spain for about 65euros, but it relies on a plastic belt clip. I'm still looking for a sensible protective pouch for mine. Any recommendations?
Thanks for the info about the Piel Frama case. I bought one of these today.
Thanks Richard. How robust is the belt clip? Does it locate so as to prevent the case from turning over whilst attached to your belt?
Graham
I'll let you know when it arrives. 🤒
link (click smart phone cases)
The case arrived and only took two days delivery from Spain to the UK. I am happy to report that I am very impressed with it. It is very well made and fits the Serene perfectly. It offers a perfect alternative to the overpriced Louis Vuitton case and I would not hesitate in recommending it to fellow Beoworlders. I wont be using the belt clip so I cant comment on it to much, however there is nice attention to detail by providing a tool to remove the fastening screw and spare plugs to hide the hole.
Thanks for the case information.
Just a follow-up re my 'Review' of the Serene as a good used buy, I quickly found that the battery seemed to need charging within 24 hours of a full charge. I initially put this down to my playing with the phone/ using the motorised opening etc, but when the problem continued even when the phone was virtually only on standby all day, I visited my local B&O dealer and had a new B&O/Samsung battery put in. Unfortunately, I now find that the same rapid battery run-down continues, even after taking the phone on and off the charger a few times to ensure that the initial new battery charge was complete. Has anyone else had a similar experience? (Incidentally, B&O dealer has indicated that any faults with these phones under guarantee involve the phone being returned to Denmark).
Florence Wilson can supply a leather belt pouch that's very strong and will suit the Serene phone. Obviously not a tailored fit!
http://www.madeincumbria.co.uk/gallery/fh_wilson.html
The key/coin pouch is large enough and sells for £10 inc post.
I have had no battery problems. I have actually been somewhat impressed with the battery life, even with the motor on.
I'm beginning to wonder whether my short time between charges may be linked to the fact that my home is not in the best reception location for my network: signals are frequently lost. Does a poor network signal mean that the phone return signal is much higher than in an area of good reception, and hence the battery charge is lost more quickly (even on standby)? Having said that, my previous Sony Ericsson seemed to keep its charge much longer with the same reception problems.
When there is poor signal the phone, keep trying to get better signal, it do this in intervals every 1 or 2 min. on your old Sony it's possible to select have often it should try, don't think thats possible on Serene. But see if you can find a Menu about energy save.
