serenata and cover art
hi all.
after hours of trying, I'm giving up to get album art - cover art displayed on the serenata. yes - i activated mtp.
even in beoplayer it didn't work. e.g under "n.music" it shows the covers (after downloading them) - copied to the serenata - bummer.
every help is highly appreciated ;-)
does somebody know from the technical side how the serenata associates the mp3/wma to the covers ?
* Does it use embedded cover art or
* does it look up into a special folder containing the cover pics etc.
thanks
finally go it running.
under m$  I had to install the mtp driver.
now everything is fine...
then an additional folder ALBUM is created where the cover art goes in....
