Screws under Beovision 8 26/32?
I am always missing out screws to my Beovision 8 26/32 - I mean them under the tv to the aluminums foot or the wall bracket. They are very small. I have asked in several building hardware store without any luck.
Do you know the dimonsions of the screws? I will post a picture in the next post.
This one :)
I think the thread is a standard M4 or M5 screw. I used another pair of screws for an alternative mount when I had a BV8 without problems. It might be difficult to find a screw with the same head as the original though
those screws are M4 x 12L
The head of the screw is up to you 🙂
I think they are M4, just make sure you ask for "counter-sunk".
Thank you very much - I knew you good guys in here could help. :)
so I can buy them from size 15 mm to 25 mm? The best must be 25 mm then?
Thanks for the link - I have ordered now ;-)
Everything is fine! :)
