Schematic for ICEsystem from Beolab 7-4 wanted
hello, is there anyone who has a schematics of the built in BL 7-4 ICE system (ICE250)?
there is only a block diagram and a wire diagram in the service manual.
As a spare part, this board is not listed.
Best regards
I think there is no shematics ..
or ..maybe there is but not for public :(
oh, that would be a pity.
is there no B & O technician who has ever repaired these boxes and has a copy of the schematics?
there is ..but if you know electronic ..go step by step..it can be repaired in component level.
It’s a *** to take apart the components. What are you repairing on it?
I'm searching for an error in tweeter connection, the tweeter is ok, but I hear no sound (except the bass)
so no soud from tweeter ..zerro..zilch ?
are you 100% that tweeter is ok ?
if so ..check mosfets and resistrors ..ect..
I'm not 100% sure that the tweeter is ok,
have another tweeter (4 ohms) connected, it comes out no sound.
When I short the tweeter I hear the woofer.
I am not sure that tweeter 4 ohm is ok.  if it is same as geleraly most of B&O..than is 6 to 7 ohm.
What do you mean short...hope you are not shorten + and -  on tweeter cable.
I'm afraid the original tweeter has already done that, it has only about 1 ohm resistance (short circuit!).
Anyway, with this tweeter the bass woofer is active,
only high notes do not come from the tweeter
