Hello all
Is anyone having success with a B&O audio system connected via Powerlink to an S8 Connection Hub?
I have an S8 Connection Hub which is currently working well sending sound from my non-B&O TV to my Beolab 17s using the optical input. I am about to give it to my sister who will use it to connect a non-B&O TV (optical in) and a BeoSound 3000 (Powerlink in) to a pair of Beolab 4000s.
I am having trouble getting it to work. I have sound when I watch TV but not from the BeoSound 3000.
Naturally, I am using a DIN to RJ45 cable to connect the BS3000 to the hub. I have an RJ45 to DIN adapter coming out of the hub and going to the first BL4000. The second BL4000 is daisy chained from the first.
When I turn the BS3000 on the hub turns on (so it’s obviously sensing it) but the speakers do not.
I’ve had the 4000s play a chirp on two occasions just as the speakers turn off (when they were already on from watching TV) but that’s the closest I’ve come. If they’re off when I turn on the BS3000 they stay off.
Any ideas welcome!
Scott
PS I am unable to use the AUX IN on the BS3000 as the new TV does not have line out, only optical.
