ROON ready endpoint for BL50
Any suggestions for a device which can acts as a ROON ready endpoint for the BL50 ?
And how this endpoint is then connected to the BL50 ?
There are rather many devices with support for Roon nowadays:
link
How about hurrying up to get yourself an OPPO 205:
http://archimago.blogspot.com/
As for how to hook it up to the BL50’s - I’d try the different options to see/hear, what is best.
I am now using a Bluesound Node 2 as ROON ready endpoint.
The BL50 master is connected via coax SPDIF to the BSN2 with fixed volume.
The BL50 volume is controlled via Essence remote and/or B&O app. Whenever the BL50 is started it will start with the set default volume.
Works all very well.
We use the Sonore microRendu in our shop connected with USB directly connected to the BeoLab 50 and also the BeoSound Core connected with Cat7 icm with ChromeCast Audio. Works perfect!
- Flere
smile and enjoy the moment
