Hello
I'm building a passive volume control to connect my turntable and RIAA preamp (Pro-ject phono box mm) to a set of Beloab 8000 active speakers.
I was wondering if the right/left signal pins on each of the two 8-pin DIN sockets I'm using for the powerlink should be shorted or if there should be some resistance between them. I have a Beolab 5000 amp laying around so I checked the resistance between pins on the two powerlink sockets on that one. Turns out there is a ~3Ohm resitance between each pin, except for the #2 pins which are ground.
So do I need to add 3ohm resistors between the two sockets, and if so, why?
