Hi Roderic, I did think about this some time ago, but abandoned the idea, and bought a BeoSystem 3. When taking a look here:
https://beocentral.com/av9000controlcenter, it seems encouraging! What connections are there on the ‘control center’? If there is a (digital) audio in, there might be a chance you could mount a modern tv on it, and feed the audio signal to the control center. Controlling that modern (non B&O) tv with a Beo4 will be another story, maybe a Neomesteren product could provide for that. And setting the surround levels etc. (if at all possible) must be done through a menu, so the ‘control center’ has to have a video output that the modern TV can handle.
Maybe you can share some photographs of the connections between the monitor and the control center?
Regards, Johan
