Replacing sound dampening in beovox m75 speakers
hello,are there any photos or advice showing the insides of m75 or similar regarding the dampening of these speakers.l need to replace with new sound proofing as the odour is offensive.recently purchased these and found dampening loosely scattered about.l’m unsure how and where to place material,as to proper sound  positioning & closeness to crossovers (possible burning)thank you..
Scattered is fine in a sealed cab like this. The last M75s I worked on had the foam layer against the sides and back with some loose inside between drivers if my memory serves me right. My photos are lost unfortunately.
Less is better but don’t stress, you’re unlikely to screw it up with these speakers.
Thanks Peter,much appreciated,apart from the odour causing need of replacement & advice for appropriate placement for acoustic values was more worried about burning issues near crossovers.
