Hi all,
Just as the thread says really. Does anyone know where I can get a replacement belt for my beogram 1100? The one on it is still working, but I wouldnt mind renewing it before it goes.
Hi all,
The short answer is nowhere.
In the best of cases,the ones found on Ebay are useless standard belts that won't be any good.
Not long ago, I had a Beogram 1000 on the bench that had a new belt from Ebay, that the owner "couldn't make work".
It turned out it was a sewer pipe gasket...
I replaced it with a correct one from my own production.
I haven't made the one for Beogram 1100 though, because, fortunately, the far majority of these belts are
still fine.
