Remote Mains Switch
Hello all,
I have a Remote Mains Switch that I am contemplating using with my Beosystem 6500. I am considering adding an equalizer to the system. Can the remote switch be used to activate an equalizer? If so, where on the Beosystem 6500 would the device get connected?
Thanks,
Aaron
Yes, you could use this. To attach an equaliser, if you want one, you remove the blanking plug on the Beomaster 6500 and use a 5 pin DIN to 4 RCA lead.
Great, thanks for the reply Peter!
