Remote Control
Hi I have a 6500 set up with and MCP, which is fine.
Can use a hand held remote with the above set up and if so which Beo 4 (?) remote?
Regards
Beolink 1000
Beo4
Or you can use a Beolink 5000 (also two way remote).
Thomas
Just
Dillen wrote:
Beo4
NOT the Beo 4 with the Joystick/Navigation button.
The one with SAT, CD, A.TAPE etc. was the "original" one.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
If still using a turntable I would go for a BL1000; then you can access PHONO with just a single button press.
(Of course you can do this with BL5000 also, but they are a bit pricey and also quite fragile)
Ralf, thank you.
Can you tell me why?
Regards
I am using a T/T - Ralf suggests using the original one. Is this the one you refer to?
