Hi I have a 6500 set up with and MCP, which is fine.
Can use a hand held remote with the above set up and if so which Beo 4 (?) remote?
Regards
Regards
Beolink 1000
Beo4
Or you can use a Beolink 5000 (also two way remote).
Thomas
Just
Beo4
NOT the Beo 4 with the Joystick/Navigation button.
The one with SAT, CD, A.TAPE etc. was the "original" one.
Ralf
If still using a turntable I would go for a BL1000; then you can access PHONO with just a single button press.
(Of course you can do this with BL5000 also, but they are a bit pricey and also quite fragile)
Ralf, thank you.
Can you tell me why?
Regards
I am using a T/T - Ralf suggests using the original one. Is this the one you refer to?
