remote control not responding at long range
burantek wrote:
I would still like to know if anyone has had issues in link rooms when a plasma is present in another room. I have read (elsewhere) that their emissions can be remarkably powerful and long ranging.
It's still just light, so a closed door inbetween should get rid of it.
But, the processors in these Beomasters are rather slow, and they have to simultaneously keep track of several command interfaces (IR, MCL, and at least two Datalink interfaces). If the IR receiver is badly bothered by a plasma TV, it will continuously feed spurious pulses to the processor causing it maybe to miss communications from elsewhere... but this is now just speculation, and once again should bother the other IR receiver (in the link room) at all ranges.
Getting back to my original bad cap theory, the MCL boxes receive their power from the Beomaster, and so may also suffer from an unstable power supply in the BM. The IR receivers are very sensitive to power supply noise.
Hi everyone
It has been a while since I have updated info, but I have finally managed to get hold of another Beolink 1000, and still no improvement on
remote response, therefore it must be the Beomaster 5500. Next step is to try and located a decent BM5500
Thanks for all your help
Did you ever move your BM5500 to another room and check if it's working there? I had a strange issue two years ago which you can find
Hi
Thanks for you response, your link takes me to a page about speakers , is that correct ?
Tony
Hi Tony,
the link should be fixed now!
Hi Hagen
Thanks for your post, I suspect something like that, but I have not the equipment or expertise to investigate as thorough as you have done. I will just keep looking for something that might be upsetting the IR through elimination.
I will also move the system to a different room or even building.
The only things that have changed in the house recently are :-
WiFi router, new microwave / dishwasher and oven, new downlighters in kitchen ceiling
I have tried it with the plasma tv switched off and the PC switched off
I will let you know if we get anywhere
Thanks for your help
Tony
Hi Hagen
After much testing and unplugging different equipment, I am now pretty sure that this interference is caused by an old LCD PC monitor in my son s bedroom whch is next to the room where the BM5500 is located. Is this possible ?
I am also unsure about an xbox 360 in the same location, the wireless system is on all the time, even when the xbox is in sleep mode, apparently this gives of strong signals at 2.4GHz
Tony
Hi Tony,
LCD monitor: Yes, it might be possible. May be the power supply of the monitor has become defect.
WLAN: As the WLAN is only emitting signals when in use (ignoring the very little traffic issued by broadcasting its SSID) I wouldn't worry too much about it.
If the problem is stable and reproducible it should be easy to track down by unplugging any suspicious device until the troublemaker is found. As I understand you, you already did this and detected the LCD monitor to be the reason. If the problem is really gone when you disconnect the monitor from the mains you should consider buying a new one. Some models have an external power supply. Thus do not only turn the monitor off but disconnect it from the mains.
Good luck!
Btw: In the meantime the pictures of my original thread have been restored.
