tournedos wrote:
Tony, yes it's a good idea to try a known good remote as the first thing. All Beolink 1000s are pretty old by now and often have contact problems especially if the batteries have leaked sometime in the past. I'm not sure how the MCP would get weak in transmission if there's enough power otherwise (display OK?) but you never know.
I certainly agree that the first thing I would have tried would be the remotes, even if just refreshing the batteries. However, I took it from the OP's posts that both remotes would act up on occasion and other times be just fine.
Yes the IR circuitry on the BM itself and the circuitry for the link feed are separate... I went after what they both have in common... IC1 as I read it.
I would still like to know if anyone has had issues in link rooms when a plasma is present in another room. I have read (elsewhere) that their emissions can be remarkably powerful and long ranging.
