Hi All,
I've had a bit of a bad experience with my Popcorn Hour (PH A-110), it's been quite clunky, having to reboot etc. So was wondering what other options you may have come across....or use currently....and are happy with. I've been recommended the TVIX HD M-6500A by my local dealer, and on paper it looks pretty good. So i'm curious if there are any other options. I also want the new solution to be controlled via my Beo5.
Thanks in advance for your input.
Ash.
