Hi all,
After some great responses from this group I sourced some Beolab 6000 and wall mounts to use as rear speakers and match in with my Beolab 1s at the front.
Weve recently moved house and have remodelled the living room removing a few wall to make it more open plan. The downside of this is that the rear wall of the living room has stairs running up it so i have no area on the wall to mount the 6000s.
So Im now looking for some different rear surround speakers that will fit and as the wall has a stair running up it I cant use anything that will protrude too far out.
I have considered using 3s ceiling/wall mounted but they would hang down too low into the stairway, and and its a similar situation with 4000s.
I believe that there is a few recessed ceiling mounted option which would work though so looking for ideas and known sources in the uk.
Has anyone come across/reviewed the bolab 2-1 or anything similar
