Dear all...
I live in a modest mid-terraced 2 bedroom property. Space is pretty limited although a recent renovation freed up as much space as possible removing Victorian fireplaces, radiators and knocking down several walls to make as open plan as possible given the dimensions.
Current TV is a BV11-46 with the sofa approximately 2.5m away and just under the same space to the wall behind. On this wall I am considering putting a speaker (or 2 if needed) to serve 2 purposes if possible; firstly, rear sound for the television and secondly, decent sound for the whole of the downstairs.
I've read many times on this forum the popularity of the A9 even though I understand it's not stereo (correct me if wrong) and not my particular favourite design from the B&O portfolio. However, sound quality and reproduction is important to me; so my question is, would the A9 be a good choice to mount centrally on the wall behind the sofa to serve both purposes? If not, the Edge, a BeoSound 2, or something else such as BL3s perhaps? I have built a smart home using Nest/Google products so the use of Google Assistant would be preferable.
Because I haven't owned any of these products before I seek the expertise of others to advise please, especially as I am unsure whether any of these speakers can also be used as rear sound for the BV11 as well as stand alone speakers. Note that I do not have front left or front right speakers.
I'll take some pictures and add below in due course to give an idea of the space I have to play with, but it is small. Wireless speakers could also be an option although I really don't think space allows for anything like BL9s (that I sold several years ago), 20s, or similar.
Any suggestions and thoughts would be most welcome and very much appreciated.
With thanks,
Simon.
