One person flat out said he'd wasted years listening to music in other ways.
An update on my experiments with BeoLab 3 as headphones.
Some of you will remember my "inspiration" with using BL3s as headphones.
Placed on floor stands, to either side of my listening position, about 1.2m from the ear, and pointing straight towards my head.
I'm seated in a low backed and comfortable chair.
I have begun introducing friends and acquaintances to the experience, and the above quotes are just a few of the reactions I'm getting.
"I'm going straight down to B&O to buy a pair tomorrow!" from one friend - who did exactly that.
If you have a pair of BL3s at home I recommend you try it out. Instead of placing the speakers out in front, pointing towards you, with you at the apex of a triangle; place the speakers right out to the side, the acoustic lens at the level of your ears - pointing towards you.
Make sure the path to your ears is free of obstacles, and get ready for aural bliss.
The soundstage will overwhelm you. The intimacy of voices and instruments is simply shocking. The detail and placement of sources an ear opener of the first order.
And it's a really fun demo to run on friends. They can't believe their own ears. I'm going to start video taping their reactions.
