Quick question in relation to Beomedia
Hi guys,
Just a quick question in relation to Beomedia, i just wondered whether i would be able to use it with my Beovision 3? Or is it only compatible with flat screens (LCD/Plasma)?
Also, is it compatible with Windows Vista?
Yes, you can use it with your BV3. Beoplayer (latest version) is Vista compatible.
Check also image below for connections.
