Hi, my friends. A quick two questions on using a Core to drive a pair of BL18 with a BL19.
1. Using Powerlink out of the Core, I would have to connect to one BL18 and then use another Cat7 cable to daisychain from first BL18 to the second BL18. THEN use another Cat7 to daisychain from the second BL18 to BL19. Correct? Since the BL19 only has a single Powerlink socket, I don't know how else to optimally make the connections (i.e., I can't connect from the Core directly to BL19 because there would be no way to loop in the BL18s).
2. Assuming my connection strategy above is correct, within the Core settings\Product Settings\Configure\Sound\Speaker Setup\Please specify the speaker type connected to enable appropriate sound processing... would I choose BL18 or BL19?
I want all the crossovers to be handled optimally so I don't know how to indicate both BL18 and BL19 are present or if only one can be chosen, which to choose.
Thanks!
