I have a Masterlink RJ45 distribution panel and I was planning to modify my current B&O system.
I was planning to go from a Beosound 4 via a masterlink cable which has the standard masterlink plug on one end and a RJ45 plug on the other end to the Masterlink RJ45 distribution panel.
I was also planning on going from the Masterlink RJ45 distribution panel to an NL/ML converter.
I have found several such cables on line. An example https://www.bollostore.com/masterlink-to-rj45
Are these cables suitable? I have seen several on eBay which mention IHC Net  https://www.ebay.com/itm/AS-IS-Bang-Olufsen-Masterlink-To-RJ45-IHC-Net-3M-Length-Black/172351035998?hash=item2820ec1a5e:rk:4:pf:0
Does the IHC Net reference a different masterlink standard and wouldn't work in my situation?
Thanks for any info.
