Question for Beosund 5 owners...
hi,
I.ve just bought a demo Beosound 5 encore and i have a question about it.
I wonder if it commes with wall bracket from the factory?
Also, does it comes with the round metal plate ( as you see in the picture- bottom black part)?
Thanks in advance for any help!
I have a BM5/BS5
The meta round plate came with it, the unit came with a table top stand only
I had to buy the angled wall bracket separately
The BS5e will be delivered standard with a flat wall bracket. Any other brackets should be ordered separately (like the table stand, the wall bracket with angle, and the floorstand). The bottom plate is standard included. The netadapter (separately) is also a standard delivery.
Hope this helps for you.
Thanks for help! I will ask the dealer to give me that part for free as he tried to charge me for it!
what is the netadapter? ...and how it looks?
thanks
May I ask you what price you paid for the BS5E?
I am also thinking about it.
