EDIT: THE FOLLOWING INFORMATION NO LONGER APPLIES TO THE CURRENT SOFTWARE (V2.2) WHICH DOES NOT SUPPORT SPOTIFY CONNECT.
Millemissen wrote:
Is this a new feature - or one, that you just newly discovered?
It was discovered / mentioned on 2018-03-24 by a poster named "Paco", here.
Millemissen wrote:
Does the Moment appear in the list of ‘Spotify devices’, when using the Spotify app?
Yes! On my iPhone, Spotify lists a bunch of Google Cast and Spotify Connect devices. The Moment is listed as a Spotify Connect device just like my Essences and my M5, and can be connected to just the same as any other Spotify Connect device.
Millemissen wrote:
When you can control the playback (skip tracks, stop/start) via the Essence Remote, can you also do it directly on the display of Moment/the wooden part?
The round volume/control surfaces on both the metal and the wood sides of the Jukebox work for volume and track skip forward and back. The touchscreen doesn't allow me to swipe, as it doesn't seem to show upcoming or past tracks the way the Moment does when playing Deezer content. Possibly because I don't have a paid Spotify plan. (I expect that this will change very shortly, given this new feature!)
Millemissen wrote:
(if you know) can you do the same with the beo remote, if the Moment is set to be integrated with a NL-tv?
I don't own a Beo Remote.
Yet. ;-)
Millemissen wrote:
How about multiroom? I can hardly believe that you can join in from elsewhere, like you can using Deezer.
Yes, even multiroom works! I started a song on the Spotify app listening on my phone, then used Spotify Connect within the Spotify App to move it to the Moment:
Login to view image
Back to the main Spotify screen and it shows at the bottom that the track is playing on the Moment:
Login to view image
Switching to the B&O app, I see that the Moment is playing from Spotify (showing Spotify Logo):
Login to view image
B&O app now-playing screen :
Login to view image
Spotify Logo at top, Multiroom link available at the bottom! :D
I added the bedroom with the Multiroom Link button in the app. Then I walked to the kitchen and joined the stream with the Esssence Remote. This was reflected as expected in the B&O app, but also showed in the Spotify app that the links had been made:
Login to view image
Here's the appearance on the Jukebox:
Login to view image
Millemissen wrote:
(Could you provide a couple of pics - these often show more than words?)
Nah, that sounds like way too much work. ;-)
EDIT: THE ABOVE INFORMATION NO LONGER APPLIES TO THE CURRENT SOFTWARE (V2.2) WHICH DOES NOT SUPPORT SPOTIFY CONNECT.
