Qobuz launched in 6 new countries incl the Nordics
To whom this may concern: Qobuz is now officially available in Australia, New Zealand, Denmark, Finland, Norway and Sweden.
In Denmark, the monthly streaming plan (up to FLAC 192 KHz) is DKK 149,99 per month, cheaper if you go for a full year.
VANTAGE
Wow! Any idea how to get this working with B&O products? Do they need google cast to work?
Airplay or CC, from the Qobuz apps.
Or use Audirvana to access Qobuz and UPnP/DLNA stream to B&o. Benifits: formats/resolution presented by Qobuz reproduced, use of B&o own multiroom.
Note: Qobuz is working to intergrate direct UPnP stream from their app also. But this is in beta and doesn't work (well) with B&o.
Thank you for your answers! I will try the easiest way first. Bluetooth from my mac over to my Beosound Moment. It sounds really good, and the qobuz says the output is 24/44 - so maybe it is? Not sure what happens to the signal when it leaves the mac:)
/R
Thank you oli!
This is just the info i need to get the best out of my BL18/Moment setup.
Have a nice weekend!
/R
@Carpola - How can I solve this without a additional dac?
/R
For the Moment you do NOT need the proposed connection with a DAC. I just double checked it.
The same if you have a BS35, A6, M3, M5, Essence mkII, Harmony or Core (Shape)
Start Audirvana, select the speaker with "wifi" (on the right, below), set the DAC on ASIO, check the Beosound Moment, you can change the settings for streaming to the Moment by selecting ">".
Then play something on Audirvana. The Moment will start and play the chosen track.
You can also do this on the Audirvana Remote (iOS)
Audirvana must be running on your MAC/PC to controll it with the app.
the Moment is the "Active Audio Device"
"Find my way" is played on the Moment
Thanks! My problem now is that the Moment don't show up in the list of Active Audio Device.. In the list I only have MacBook Speakers. The Moment and Mac are on the same wifi...
I only have a trial on Audirvana to check that I can make it work - maybe that's the problem?
/R
