Robert_A wrote:
@Carpola - How can I solve this without a additional dac?
For the Moment you do NOT need the proposed connection with a DAC. I just double checked it.
The same if you have a BS35, A6, M3, M5, Essence mkII, Harmony or Core (Shape)
Start Audirvana, select the speaker with "wifi" (on the right, below), set the DAC on ASIO, check the Beosound Moment, you can change the settings for streaming to the Moment by selecting ">".
Then play something on Audirvana. The Moment will start and play the chosen track.
