Putting A9 in the sun...
Hi all,
Looking at adding the LG CX / Stage / Stand combo to my setup but it would mean moving my A9.
The easiest place, without wallmounting, is on the landing but this would be next to a floor-to-ceiling glass window which is south facing. Has anyone had any issue with sun-damage with the A9 in direct sun?
Thanks,
Nick
I have a very similar issue. I would like to buy an A9 but the best place for this appears to be next to south facing glass doors: Mediterranean sunshine.
Did you move it into the sunshine? Any issues / UV damage?
Thanks for the pointer - that’s a valuable thread.
I think the info I’ll draw from this all is that direct hot sunlight is probably a bad idea! I’ve found an alternative in the Level, which also has the benefit of not being overkill in my small apartment…
Cheers!
