Hello forum
I have a Bosscom remote cable, that I thought I could use a puc cable - but i does not work. What cable do work? From the RJ45 to the DVB box?
Hello forum
Maybe try one from Steve:
It looks like the right one. Do you know if he shippes to denmark?
He ships free - anywhere in the world! 🙂
Another recommendation for Steve here. I've actually found his IR Blaster cables to be better than the originals.
Lee
Thanks guys!
Yes, the cable mentioned in the thread above is the correct one and this includes free shipping to Denmark by Airmail.
Kind regards, Steve.
Thanks - and how much for 2 or 3 meters? :)
You'll need to order from the website. It says it's a 1m Cable on the drop-down option, then says in the description it's a 3m lead as standard.
I am almost certain it's a 3m cable, but maybe Steve can confirm?
Here is the link to the page you need.
Lee
The link only shows 1 meter and the drop down only shows 1 meter ;)
