Nite nite everyone.
I came across and ad for a phillips pronto device full in box.
And wanted to check with you that this is the only hardware needed to learn "any" IR code to feed the Beo6?
I think I've understood that i will need some more software to convert formats: are this software available and is the conversion something easy done?
You have understand my goal: being able to use the Beo6 with any IR controllable device and being autonomous to program it as needed.
Did a quick search on this forum and the archived one but didn't find and clear answer and some intel about "protected codes" add confusion to me.
Thanks a lot.
