Projector install with bvis 7-40 mk3
yes it should be fine, you will have to manually turn on the projector or program direct control off the beo5 or use a lintronic box.
I recommend a Lintronic - 238 box for cinema control. The box can be triggered by the cinema control outputs of the BV7-40 and can control the projector and the motor screen by IR or RS 232.
More info: http://www.lintronic.dk/AppNote_BeoSystem_RS232_IR.pdf
http://www.lintronic.dk/Support.asp?Supported_BRANDNAME=EPSON
My setup even controls light and blinds. Works great.
Stefan
No. BV7 just delivers a close/open contact. This contact - there are two actually - trigger the Lintronic box, and the box will control all your cinema devices via a macro incl. the popcorn machine. See the Lintronic instuction manual.
Stefan
