Product Config Guide
Is it still possible to download the PCG? There is no link from the "products" section of the main site.
Excellent. Many thanks - now installed.
David
So is there a way of getting this to run on a Windows 10 PC?  I get error messages when I try to run.
I used to have an old XP laptop to run it on, but no more ..
Appreciate anyone's help!
Yes you will need an XP PC. I also tried it in Windows 10.
Thanks David - I thought that may be the case!
Hi Guy,
Use the Microsoft Hyper-V feature to install a Windows XP and then in this virtual machine you can install the product configuration guide.
I once did this on a windows 7 pc with the MS integration feature. This was the MS Virtual PC with a MS image of Windows XP.
Thanks Ralph-Marcus - I may well give that a try.
But in the meantime, I just found an old laptop that my mother-in-law had dropped off for me to 'fix'.  I booted it up to discover the wonderful VISTA operating system 😮, downloaded the PCG and it works perfectly! 🙂
Out of interest what is the Product Config Guide ?
It's a simple B&O tool where you can configure a virtual multi room system by choosing what B&O components you have in each room (audio and video), and (for example) whether you are using MCL (like me!) or ML, plus what speakers are being used.  It then gives a quite detailed summary of how to connect the components (what leads are required), and what option settings they should all be in.
It's getting a bit dated now, but I find it very useful to double check my settings, cabling requirements etc.  It can sometimes be useful for answering other people's setup questions on here.
I don't think any modern (NL-era) equipment is included (and I'm not firing up VISTA to check! 😁)
