Problems with Beosound 9000
Hi everyone.
My parents have some issues with their Beosound 9000. It plays CDs properly but the slide doesn't work as it should.
If I try to change from CD1 to any other CD, the slide moves less than an inch and gets stuck. After ~30 seconds it drops to CD6 and the system seems to turn off. And by 'drop' I really mean drop, just as if the engine releases the shaft and the spring pulls the slide down. Doesn't sound very healthy...
If you don't understand anything because of my bad english, I'm happy to explain it again.
Do you have any suggestions what to do?
Regards.
Has it been oriented in a different way before? For example laying down flat, and now upright on a wall?
It has alway been mounted on the stand and it worked in this position until a few weeks ago. No significant changes were made afaik.
Could be a problem with a dirty tachowheel inside and/or misalignement. The latter can be fixed with the service option. (Can't remember at the moment by heart.
where are you based?
Mine displayed similar symptoms a few years ago. Turns out the little glass prisms used to sense if fingers are in the way of the pucks movement were dirty and needed cleaned. Try cleaning those little glass protrusions at the top and bottom near the open side of the glass cover with a swab and some alcohol or even water and see if that helps.
@KingOfSnake: I'm based in the city of Duisburg, Germany.
@Jett: Thanks, I'll try that later.
I copied this info a while ago from another thread (maybe Archived Forum):
Hi folks! Need help!
I've owned my Beosound 9000 for about 4 plus years and for the first time, I can't get the CDs to align after playing.  They all stop in random positions.
I've consulted the manual to do the Position OK for the CDs to no avail.  I went yesterday to the dealer and he suggested to clean the small glass sensors and that didn't work either.
I've had power outages from time to time and have had to reprogram the BS9000 w/ the remote.  For some reason it took numerous attempts this time to link the remote w/ the player.  Could I have inadvertently screwed up the logic within the BS9000?
Totally frustrated!  Thanks in advance for any suggestions to remedy this issue!
I'm not completely clear on exactly what the nature is of your "alignment" issue but I may suggest the following:
When installing a new laser unit into the BeoSound 9000 (which I have done successfully on both Mk II [eBay sourced CDM12.4 laser only] and MK III [B&O sourced VAM1250 complete laser assembly]), one has to run two specific test mode driven alignment procedures after completing the laser change-out. I am not sure of the numbers of each off the top of my head but I believe they are TM71 and TM73.
Anyway, the exact procedure is detailed in the BS 9000 Service Manual which is available to Silver and Gold members here on BeoWorld.
When these test modes are activated, the sled moves along and stops at each disc carrier, along the entire track length, clamps and releases, etc. and notes/references the proper position back to the computer. Perhaps when you lost power, these "parameters" were lost. The test mode activation can be done by yourself and you can use your Beo4 remote to initiate them.
If you require more detail, I would suggest first referencing the Service Manual. Should you have any questions, please feel free to ask me and I will do my best to explain.
Also, did you mean by "did the Position OK for the CD's"  that you already tried this? If so, please disregard my suggestions.
Good luck,
Michael
Thank you for your reply and suggestion.  I have been away on business and could not reply/try your suggestion on the test.  I will try it this weekend.
Now you mention the service manual for the 9000.  Is that only avail to gold/silver members here or did I receive that when I purchased the 9000?  How else would I find it if it was not included with the unit?
Thank you for your suggestion and I hope it works!  Something this expense should not be causing such a basic problem IMHO...
Regards,
Terry
Hi Terry:
I have confirmed that the post-laser-change required Test Modes for the BeoSound 9000 are TM71 and TM73.
I use my Beo4 remote to activate the tests.
TM71 is called "Mechanical Test of Finger Protection, Sledge, and Led". TM73 is called "Adjustment of Auto Positioning".
The Service Manual for the BeoSound 9000 would not have been included with the BeoSound 9000. It is available to Silver and Gold BeoWorld members. Only User Manuals were originally included for sure.
Here's what the manual states concerning getting into the Test Mode: "Press SHIFT 90258 with no more then 2 sec. between the individual entering. The remote control has to be in (RADIO or) CD option. In Test Modes the tuner is fully functional and may overwrite the display but TM will continue. Select CD to view CD test modes."
I've done this many times after servicing the BS9000 but it can be a bit tricky. Remember to press the CD button after successfully getting into the Test mode. You'll know you are in as the LED tuner display shows TM and then you enter the particular number that you want. These modes are quite interesting to watch as they are very much robotic as the sled, door, etc. goes through various exercises to test the parameters.
Good luck and I look forward to hearing how it goes for you.
Michael
Michael:
You are a ROCK STAR!!!
I did the Test 73 and it worked like a charm.  Never mind how long it took to get it into TESTMODE.  It's as if the remote BEO4 is acting up or maybe needs new batteries.
In any case, I did the Test 73, then I got a APS Successful (or something like that) message and each CD now aligns properly when going from CD to CD.
I truly appreciate your assistance on this!  I couldn't have done it without your knowledge and input!  A millions thanks!
Regards,
Terry
Hi Terry:
That is truly wonderful news! My pleasure as it is always rewarding to see our beautiful B&O up, running and doing what it is designed to do. And especially great if one doesn't have to spend money to achieve that end.
Yes, the TM73 was the most difficult for me after my Mk III laser change as it required a few runs for it to "take".  On my Mk II, it took on the first run.
In reading your original post, I concluded early on that if the Test Mode adjustments were to solve the problem, that it would be the TM 73 and not the TM 71 that was at the root of the problem.
Now, If I can only make some progress on my "in-need-of-repair" B&O! I have two BeoMaster 6500's with blown output stages, a BeoSound 4000 in need of a door belt, four BeoLab Penta I's that require complete restorations and a BeoCord 6500 in need of belts. I'll get to them slowly but surely  (I just built a Dim-Bulb Tester to help with the BM 6500 troubleshooting) and will enjoy every minute of it!
The best to you Terry!
Sincerely,
Michael
Lowell, Massachusetts, USA
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
If you want to contact me at morethanav we can sort for you - have you still got the original packing?
Thank you guys, the cleaning did it! 🤒 🤒 🤒
