Hi.
I bought a second hand product B&O 6 touch remote a couple of months ago.
As I unwrapped my new beautiful product I realised the product was a lot more than just a remote control. It needed to be paired in a different way than other remotes, and was a lot more complicated to start up.
So I tried to solve the connections myself - Big mistake..
As I tried to pair to BS 9000 and BeoSound 4 with my new product, suddenly none of my old remotes no longer worked (BeO 4).
I think somehow I have changed the settings by mistake in my BS 9000 and BeoSound 4. Both of them made a "click" sound and turned off. Since then I have not been able to use any of my remotes which is quite annoying as time goes by.
Any suggestions to how I can connect my B&O 6 remote so that everything works again, thank you!
