Problem with beovision-6 timerstart
My beovision-6 26" has the timerstart feature in the menu
Problem is when I for example set i to start next morning at 7 in the morning and shut of like 1 hour later it never starts the tv. However, if I during that hour timespan manually turn on the tv, it automatically turns off the tv right on time.
This doesnt do me much convenience as You may guess :)
Any ideas?
I have the old beovision-6 with soft speaker covers
The b&o repair shop told me that they have never ever seen anything like this and have never ever experienced a technical issue due to a electrical component causing this error so I assume I must be doing something wrong :)
I've got the same TV you've got. While I don't have time to test the exact same you do, I did just create two timers:
1. turn off at a time 5 minutes in the future
2. turn on again at a time 10 minutes in the future
Everything worked as programmed. You could program the same thing and check if it works, too. Maybe that helps.
Cheers
Thanks for the ckeckup.
Nope It did not work like that on mine, it only shuts down on time not on. A shame I always get the odd ones when I buy my beo gear, hate the hassle of moving everything back and forth to the store.
Sorry to hear that. Good luck with that repair!
