Problem with Beomusic and Deezer
Hi
Today i notice a problem using Deezer through the Beomusic app.
Every tune just play 30sec and then change to next tune.
Have i unfortunately change any settings?😮
Regards Erik
I have had the same problem. Try logging out of Deezer in the app and then log back in.
Sounds like your Deezer subscription has expired and you are on the "free" tier. You need a Deezer Premium+ subscription
Not necessarily expired. I have had the exact same problem multiple times. Merely have to re log in an problem is solved.
Thanks it worked to log out and in again.
