Problem with Airport Express & BL3
I have my BL3s connected to an Apple Airport Express and am streaming music from my iMac/itunes. However the volume is incredibly loud (these babys are powerful!), I cannot figure a way to attenuate the sound output. It ssems the only way is to turn the volume right down (and I mean right down ) in iTunes but this is still a bit too loud and there is virtually no fine control. It is not satisfactory. I live in a flat and cannot afford to have the volume too loud at certain times of day i.e. when my wife and/or neighbours are in.
The Beolabs are set up as the manual specifies with Line selected.
Any thoughts?
Looks like you want a pair of
Thanks Alex,
this solution looks good, I will investigate further.
I assume you have tried to fiddle with the preferences for AirTunes in:
Preferences > Advanced > General Tab > middle section which describes how iTunes handles sound through Airport.
I have BL3's connected to a BS9000 to which an AEXpress is connected through AUX input, and I have had no volume abnormalities.
Please note that my preferences are as follows (your results may vary):
Streaming buffer size: Medium
CHECKED: look for remote speakers connected with AirTunes
UNCHECKED: Disable iTunes volume control for remote speakers
CHECKED: Allow iTunes control from remote speakers
Hope this helps.
-Sal
I read on the Apple discussion boards that you may have luck with adjusting the equalizer in iTunes, specifically, turning the preamp all the way down. I think iTunes automatically turns the preamp on. That did it for me.
Your mileage may vary,
JBB
