Problem with A9
Hi everybody  my A9  disconnect  when  listen music  in my iPad  a person what a idea  thanks
Probably not a good connection to your router. If your iPad and/or A9 is far from the router and/or if your router is weak/slow/old this is what will happen. I would suggest moving your units closer together if possible and also check that you have a "good enough" router. I strongly suggest you use a 802.11n router that has mimo-antennas. Good Luck!
